Wannan tattunawa ta zama daɗaɗɗiya. Yi sabuwar tambaya idan ka na bukatar taimako.
How do I convert a text to a hyperlink
  • 2 amsoshi
  • 1 yana da wannan matsala
  • 88 views
  • Amsa ta ƙarshe daga genie
I would like to be able to highlight a text and turn it into a hyperlink. How do I do this? Thanks.
Mafitar da aka zaɓa
Select the text, Ctrl+K, paste the link (Ctrl+V), OK. The composing format must be HTML, not plain text.
https://support.mozilla.org/en-US/kb/hyperlinks-in-messages-not-working#w_problems-with-composing-messages
Karanta wannan amsa a matsayinta 👍 1
Zaɓi Mafita
Thanks for the reply. This seems to work. However the workflow that I have had to follow to make it work is as follows:
1) Copy the link to the clipboard (by highlighting the link and entering Ctrl C)
2) Highlight the text
3) Ctrl K to open dialogue box
4) Paste link in link location (Ctrl V) and then click OK
